16 years agoNios II Problem!
Hi Sir/Madam, Actually I am finding one problem in my design that after fusing the .sof files when I run software the processor get paused. This problem comes most of the...
16 years agomostly if all elecric connections ar correct, this is a timing issue
is your memory at 0x80xxxx an external memory (i assume yes due to the memory size) do you use sdram ? if yes, have you cecked that the phase shift of the sdramclock is correct ? have you checked your timing ? do you get timing warnings ?
