16 years agoNios II Problem!
Hi Sir/Madam,
Actually I am finding one problem in my design that after fusing the .sof files when I run software the processor get paused. This problem comes most of the time when I enable the signal tap. When the signal tap is disabled the software runs properly. what comes in console window of Nios II is as given below. I will be thankful for your kind sugestion. Have a nice day! Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x00C10C60: verified Initializing CPU cache (if present) OK Downloading 00800020 ( 0%) Downloaded 63KB in 0.7s (90.0KB/s) Verifying 00800020 ( 0%) Verify failed between address 0x800020 and 0x80F89F Leaving target processor paused. Regards: SB Yadav2 Replies
I restarted Nios, Quartus, theUP3 kit and then the problem was no more....probably this is not the exact solution, but certainly one option to consider....
(though this is an year old post, i am replying here so that someone else who is looking for solution can read this...) - Altera_Forum
It can have all sort of reasons, most probably a faulty memory interface. Search for this error message in the forum for suggestions.
