noobisme
2 years agoNios II Flash programmer download error
hi! My device family is cyclone 10 lp,flash is epcs64 I use the Serial Flash Controller Intel FPGA IP by Pltform Designer to download, it will be a error when I download by Nios II Flash programme...
- 1 year ago
Hi
For your NiosII have you set the NiosII to boot from the Serial Flash?
Did you set the linkerscript correctly for either execute in place or bootcopier boot?
https://www.intel.com/content/www/us/en/docs/programmable/683104/current/bsp-editor-settings.html
Jingyang, Teh
tehjingy_Altera
1 year agoHi
Did you regenerate the HEX after setting the linkerscript in the BSP?
If you are booting from the Flash, there will be 2 hex file. One is the onchip and another will be the Flash hex. (epcq or gsfi in the naming)
noobisme
1 year agoHi
I already solved the question by set the Reset vector as right offset,then the HEX Data can smoothly run.
Thank you for your help with the utmost respect.
Noobisme
