noobisme
2 years agoNios II Flash programmer download error
hi! My device family is cyclone 10 lp,flash is epcs64 I use the Serial Flash Controller Intel FPGA IP by Pltform Designer to download, it will be a error when I download by Nios II Flash programme...
- 1 year ago
Hi
For your NiosII have you set the NiosII to boot from the Serial Flash?
Did you set the linkerscript correctly for either execute in place or bootcopier boot?
https://www.intel.com/content/www/us/en/docs/programmable/683104/current/bsp-editor-settings.html
Jingyang, Teh
noobisme
2 years agoHi
I have been researching this issue,How can i get Hex Data?
I'm able to get Sof Data and Elf Data, and I can't translate Elf Data to Hex Data.
so I can't use the Convert Programming Files tool for this process,because I don't konw how to translate Elf Data.
Is there any way to translate Elf Data to Hex Data?
