GBusl
7 years agoNIOS II doesn't boot from QSPI in MAX 10 devkit.
I've created a project with NIOS II just to blink LED and boot from QSPI flash. Everey this is successful but It's not booting. How come there is no error and it is not booting? --Please help--
- 7 years agoHi Galio, Attached is two zip files, one is the design to boot from QSPI flash on MAX 10 FPGA Dev-Kit and another is the PFL(Parallel flash programmer ) use this project sof file to program the FPGA to work as a bridge to the flash. then Choose the design pof file to program the flash then reset the board to boot from the flash successfully. This design been tested on MAX10 Dev-kit and working fine. Please let me know if you still need any support. Regards,
Ahmed_H_Intel1
I will share with you an example of this MAX10 QSPI boot.
Also I am waiting your example to check what you are doing wrong.
Regards.
