16 years agoNIOS II do not run
Hi together, I have a problem. I´m debugging a NIOS II project and it is working. I saved the .sof and .elf file in a 16MB-flash. Then I go on the projectname->debug as->NIOS II Hardware. In the...
16 years agoHi,
Have you specified which mem area the nios cpu goes after reset? Both in the SOPC and the bsd editor? And, Nios hangs when you use stdio like printf and don't connect the blaster. So set stdio to null in the bsd editor. apus
