13 years agoNIOS II and Cyclone III Remote Update
Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a projec...
13 years agoHi Julien_92,
I have already make it follow what Cris72 had said, I copy the steps below, besides, you can may some useful info at alterawiki & search EPCS bootloaders. - unzip the files in a new directory - open Nios II command shell and go there - change EPCS_SRC_ADDR in boot_loader.h with desired boot address for Nios application - build the custom bootloader, which generates a epcs_controller_boot_rom_A.hex file (simply type 'make') - replace the existing epcs_controller_boot_rom.hex file in your Quartus project with the newly generated one (thus removing _A) - select Quartus Processing menu, then Update Memory Initialization file - select Quartus Processing menu, then Start -> Start Assembler - the generated sof file will boot from the specified epcs address
