8 years agoNIOS II - Downloading ELF Process failed (Arria 10 FPGA Dev. Kit)
Hello, I’m trying to running ‘hello world’ project by making up basic Nios II system. I encountered the error message : “Download ELF Process failed”. - Target FPGA board : Arria 10 GX FPG...
8 years agoto Anand Raj Shankar, anilinaltera
Thank you for your reply. I just solved my problem from your comments. The main cause was that I didn't assign 'clock' and 'resetn' signal to the appropriate pins of Arria10 FPGA. I assigned 'clock' signal to PIN_AU33 (1.8V 50MHz reference clock) and 'resetn' signal to PIN_U11 (User Defined Push Button). Then Nios gave me perfect response. kiyeop
