14 years agoNios crash (JVM terminated)
Hi, I am using NIOS II IDE, Use Windows 7 x64 version Recently, my nios2 keep have problem. NIOS Error message is showed below (JVM terminated.Exit code=1) (JVM terminated.Exit code=-...
11 years agoHello,
Please share if there is a solution for this. I am having a similar problem. My code has extensive printf statements and the IDE almost always crashes with different exit codes like 3, 1, -7881776 etc I noticed that the eclipse.ini does not have "-vm" option set. But, still it gets loaded somehow as C:/altera/13.0sp1/quartus//bin/jre/bin/javaw.exe All my efforts to change the path to another jdk/javaw.exe failed as the above mentioned path is getting loaded somehow. Could someone help me to understand which all scripts are called while eclipse is launched. https://www.alteraforum.com/forum/attachment.php?attachmentid=10497 https://www.alteraforum.com/forum/attachment.php?attachmentid=10498
