14 years agoNios crash (JVM terminated)
Hi, I am using NIOS II IDE, Use Windows 7 x64 version Recently, my nios2 keep have problem. NIOS Error message is showed below (JVM terminated.Exit code=1) (JVM terminated.Exit code=-...
11 years agoHello,
Kindly share if this problem already has a solution. I have a similar problem. My code has extensive printf statements. The IDE almost always crashes. My eclipse.ini does not have "-vm C:/altera/13.0sp1/quartus/bin/jre/bin/javaw.exe" But this jawaw.exe path gets loaded from somewhere. All my efforts to change to another jdk/java path failed as the above mentioned path is always getting loaded somehow. Even if I hardcode the javaw.exe path in eclipse.ini, the above mentioned path gets loaded. Could someone help me to understand which all scripts are called when eclipse is launched. http://www.alteraforum.com/forum/attachment.php?attachmentid=10495&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=10496&stc=1
