14 years agoNios crash (JVM terminated)
Hi, I am using NIOS II IDE, Use Windows 7 x64 version Recently, my nios2 keep have problem. NIOS Error message is showed below (JVM terminated.Exit code=1) (JVM terminated.Exit code=-...
13 years agoThis happens to me all the time under Windows 7. Quartus versions 8.0, 8.1, and 9.1 have all done the same thing. Seems to happen more often if there are compiler errors noted in red on the document. But I've had it just go "poof" when clicking on the debugger icon.
I make sure to hit CTRL+S to save my work after any change I make. The IDE is completely unreliable. None of these problems happened to me running the same versions under Windows XP.
