14 years ago
NicheStack CII
Hi there,
I've been implementing Altera Datasheet " Using the NicheStack TCP/IP Stack
Nios II Edition Tutorial, Jan 2007", but I'm getting some difficulties and I tried a lot to discover it and I couldn't do that. So please any one could help me finish this, I'd appreciate it, and Thank you in advance :)
The message I'm getting after run is
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
properties
Hardware: Cyclone II Development & Educational board
Software: 1- Quartus II 7.2 web
2- Nios II 7.2 IDE.
    Are you using a DE2 board with a DM9000A controller to Ethernet?
    Quartus 7.2 has LWIP instead Nichestack.
    Look that (terasic support):
    I am afraid that the DM9000A does not support to be initialized in the Quartus II 9,0 or later version. So it is quite difficuilt to port the DE2_NET project from NIOS II 7.2 IDE to NIOS II SBT 11.1 directly.
    In the Nios II v9.0 or later, the TCP/IP includes the networking stack of the Nichstack, however, the DE2_NET project was built on the LWIP. The driver for the DM9000A should be different in the Nichstack to the LWIP. Then, if you want to migrate the DE2_Net project to Nios II v11.1, you have to create a new driver for the DM9000A at first.
    @ Socrates,
    Thanks to you for comment, but I wonder is there any specific technical support on Altera site or else where has a full descriptions and steps for Ethernet. Such as, "Rapid Prototyping of Digital Systems SOPC Edition by James O. Hamblen".
    Your processor is not running. Either the CPU is in reset or some SOPC/QSYS components are not working at all.
