14 years ago
Newbie - Where to put my Time/Energy
Hi All,
I am new to FPGAs with a strong background in embedded micros. I have a new project where an FPGA would be a good fit. I have started into the FPGA world having:
Installed Quartus and developed the 4-bit counter/LED blinker, no problem. (DE0 board)
Studying Verilog.
The application will be reading parallel output from a couple of high speed ADCs and processing that data into a serial stream. It will incorporate a UART for handling commands and to provide a debug output.
I would like to start with the UART. I believe that I will require the NIOS processor to do computational manipulation of the data.
There are many paths that can take all my time like studying the avalon interface specifications etc. I have to be efficient with my time.
I am looking for advice on what would be a reasonable path to take to to get going to avoid heading down dead ends or "rabbit holes".
Rich
    --- Quote Start ---
    I am still not sold on the need for the FPGA and time/money is of the essence. I think an ARM micro running at 120MHz may be just fine. I will have to do some number crunching to find out.
    --- Quote End ---
    You have to be pragmatic. Select the right device for the job.
    A microcontroller might be appropriate, or a microcontroller plus a support CPLD. For example, the new STM32 ARM micros have a 168MHz Cortex-M4 core, single-precision floating-point unit, an external bus interface, and have GPIOs at up to 84MHz. Go and request a free STM32F4-Discovery kit;
    http://www.st.com/internet/evalboard/product/252419.jsp
    (The 'order free kit' link is on the right side under "Key Features").
    I'm thinking of using this kit as the basis for a custom FPGA programmer and monitor (power on/off, voltages, currents, temperature, etc).
    The USB interface of the micro will be used to program the FPGA, and then I can communicate via USB as well. I'll even try to make it look like a standard USB-Blaster so that SignalTap will work without having to write custom code.
    --- Quote Start ---
    I will be a bit disappointed if the micro is ok as I am interested in learning technology that is new to me....
    --- Quote End ---
    Who says you have to stop learning? If you invest a little time on the side to learn new devices, you'll generally find that they are a solution to a future problem. If you don't take the time, then you're not going to have a decent breadth of knowledge ....
    Cheers,
    Dave
    Yes Dave, you have nailed my weakness, the struggle to be pragmatic and systematic. I tend to bounce around and to need to start seeing progress before all the ducks are lined up. I usually blame being spread too thin but it is more of a personality disorder. ;-P
    I ordered one of those kits. I am very familiar with the NXP ARM micros (Used to be an NXP micro apps eng) so that may be an easier path.
    I will keep learning the FPGA world. I am going to order an Analog Devices ADC eval board to interface to the FPGA demo board and eventually start handling signals etc.
    Rich
    --- Quote Start ---
    --- Quote End ---
    I like the NXP parts a lot. However, I was looking for high-speed USB and Cortex-M4, and NXP do not have anything yet.
    --- Quote Start ---
    --- Quote End ---
    Which ADC?
    What is your actual application, with regards to the ADC, and the WiFi connection? If you have to perform some signal processing, I can offer suggestions.
    Cheers,
    Dave
