16 years ago
New to Modelsim, and a beginner question
So i try using modelsim altera to simulate my simple verilog code, i recently have had to switch to altera so i am very new.
I have written a simple 4 bit adder and i want to simulate it,
module chos(;
reg[3:0] a,b;
reg cin;
wire[3:0] sum;
wire cout;
full_adder_4bit dut(a,b,cin,sum,cout);
initial begin
a = 4'b0000;
b = 4'b0000;
cin = 1'b0;
# 50;
a = 4'b0101;
b = 4'b1010;
# 50;
a = 4'b1111;
b = 4'b0001;
# 50;
a = 4'b0000;
b = 4'b1111;
cin = 1'b1;
# 50;
a = 4'b0110;
b = 4'b0001;
end
endmodule
** you can be sure that my full-adder_4bit module is correct. anyway when i try to simulate it . it says the top partition has no logic in it.
How do you write a testbench, such that you can get something showing up in ModelSim?
    In Quartus first make the designe the Top-Level Entity!
    After that you have to add the testbench in the projekt-settings.
    Go: Assignments\Settings -> EDA Tools Settings -> Simulation in tht page check the Compile Testbench at the NativeLink Settings tab.
    There you add your testbench file, and i hope it will run properly ;)
    Did you use quartus II>? i am using quartus II and then it migrates to modelsim :(
    I tried your testbench code and it works fine with my 4-bit adder module.
    All you need to do, is making a new projekt in modelsim, add the design and the testbench file, compile them, and start the simulation.
