16 years agoNetlist writer
Hi I am using the SOPC builder to create a NIOS based system. I wanted to use an open source tool minSSTA to perform timing analysis. The tool accepts .bench: circuit netlist file - Here is...
16 years ago --- Quote Start --- Hi I am using the SOPC builder to create a NIOS based system. I wanted to use an open source tool minSSTA to perform timing analysis. The tool accepts .bench: circuit netlist file - Here is a brief description of format of .bench file: ( from the tools readme file ) It starts by declaring the primary inputs/outputs. As an example, INPUT(G0) -- 'G0' is a primary input (PI) OUTPUT(G17) -- the output of gate 'G17' is a primary output (PO). Since the PO name is not explicitly given, in MinnSSTA, the POs are named after the gate providing the signal, e.g., POG17. The netlist is described by a set of equation-like descriptions. For example, G10 = NOR(G14, G11) means that G10 is of NOR-type, and it has 2 inputs which are outputs of G14 and G11, respectively. So my question is can i get gate level netlist from the quartus tool in any format. I can write a script to convert it Also I am not able to view the nios cpu in rtl viewer, so if use it in my design will i atleast be able to see its gate level netlist. Thanks --- Quote End --- Hi, you can choose under EDA tool setting -> Timing Analysis -> custom. Quartus writes out a gatelevel netlist and a SDO file. The sdo file contains the timing information. The required libraries for the altera elements can be found under: <Quartus install Dir>\quartus\eda\synthesis. Kind regards GPK
