19 years agoNeed Help
I worked with Altera board and I want to plot expermental results on the screen. I already connect LCM to the board. Is it possiple to plot these results or even write anything to this LCM. ...
19 years agoHi
The link below says Pattern generation is posible I guess You can go through this and figure out how to generate a patternof your own. http://users.ece.gatech.edu/~hamblen/camlcd/doc/trdb_lcm_userguide_061130.pdf
