12 years agoNeed help to implement 2D array ROM in vhdl
Hi, I wanna implement 16x16 array. each entry in that 2D array will be of 8 bit. so I wrote this. TYPE SBOX is array (15 downto 0, 15 downto 0) of std_logic_vector(7 downto 0); // is this...
12 years agoIsnt this 3D memory :
TYPE SBOX is array (15 downto 0, 15 downto 0) of std_logic_vector(7 downto 0); // is this correct? You are defining a block of 16-bit x 16-bit and 08 of these blocks in 3rd dimension ??? So you will be giving it Row address ( range : 0-to-15) and Block address ( range : 0-to-7)
