10 years agoneed help on state machine. Illegal character
I try to build state machine in the IEEE 1394b page 446 (pic attach) by using wizard on Quartus. When I try to build condition from R1 to R0. I have problem with the "+". Do you have any suggestion?
thanks5 Replies
thanks for you help
you need to convert expression like "arbTimer >=resetDuration + RESET_WAIT" to boolean equivalent like "cond_input = (arbTimer >=resetDuration + RESET_WAIT) "
and use cond_input in stateflow diagramm. I advise you to replace complex condition with simple one, and later in code you can insert how to calculate it . - Altera_Forum
So find the illegal Verilog syntax near position 28 and remove it.
Don't ask me what it is or on what line - only you have the Verilog code and my crystal ball is broken. - Altera_Forum
--- Quote Start --- The screenshot is too small to see anything. --- Quote End --- thanks for reply in the first picture show that condition from R1: Reset Wait to R0: Reset Start reset with the condition " arbTimer >=resetDuration + RESET_WAIT " when I input the " + " in there, Quartus show another window which is send pic said " illegal verilog syntax found at character position 28, near + ". How do I fix that problem? - Altera_Forum
