16 years agoNCO:Sine Waveform
Hi. I am trying to use the NCO to generate the sine waveform. However, the waveform obtained is different where it is attached. May i know where to modify it in order to get the correct the sine waveform?
FYI, i chose the parellel CORDIC algorithm to generate sine waveform. Spec: Phase Acc: 32 Angular Position: 16 Magnitude Precision: 16 Clock rate: 50M desired freq: 1M phi_inc_i: 85899346 Thanks2 Replies
I try to add phase dithering with diff level(min, average and max). However, three look alike. Do u have any experience on it(add phase dithering or other noise)?
thanks - Altera_Forum
Looks like you have a sign problem. The NCO output is a signed vector, and I assume that you are displaying it as an unsigned.
