14 years agoNCO phase drift
Hello, I have an NCO generating a 60 Hz sine output. input clk = 10 khz phase accumulator precision = 32 bits angular resolution = 32 bits magnitude precision = 10 bits phase incr...
14 years ago --- Quote Start --- Your frequency tuning word is probably being rounded. --- Quote End --- Unlikely. NCO implements simple modulo integer arithmetic. The given constant will result in an excact output frequency of 10e3*25769804/2**32 = 60, within the accuracy of the crystal generating the 10k input frequency. Ignorant question, how do you determine "phase drift over time"? Comparing with mains frequency? Then you'll likely see a "drift". P.S.: I presume that "drift" doesn't mean the phase jitter of one input clock period.
