14 years agoNCO help...
Hi i'm trying to test a fixed point filter on a FPGA board, my filter has an input of 16 bit, but the maximum value it can take without saturation is 1023 which is 11 bits. so far the only signal i'v...
14 years agoBut the link you provided shows rate transitions located correctly.
Remember Matlab will help you model the design for testing. The actual implementation is up to your work (unless your tool generates design).
