14 years agoNCO help...
Hi i'm trying to test a fixed point filter on a FPGA board, my filter has an input of 16 bit, but the maximum value it can take without saturation is 1023 which is 11 bits. so far the only signal i'v...
14 years agoAre you displaying values correctly? I think you have set it to sign and magnitude instead of 2's complement since the sine values suddenly dip max negative after positive section.
