14 years agoNCO help...
Hi i'm trying to test a fixed point filter on a FPGA board, my filter has an input of 16 bit, but the maximum value it can take without saturation is 1023 which is 11 bits. so far the only signal i'v...
14 years agoIf you are working on schematics then just connect MSB of NCO to all remaing MSBs of filter input.
if you want VHDL then: sine16 = std_logic_vector(resize(signed(sine11),16)); You can also keep your NCO on 16 bits then select its 11 MSBs instead of setting it to 11 bits., your choice ...
