OLevy1
4 years agoNative PHY LTD and LTR Switch
hi,
i am using the StratixV GX Native PHY in Rx Mode to receive ONU Bursts (the same way the OLT in NGPON2 Network - chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/viewer.html?pdfurl=https%3A%...
OLevy1
4 years agoThanks Farabi,
I don't really understand:
the 'rx_digital_reset' signal between 2nd and 3rd bursts is '1' for 83 clocks (311MHz), 250nS.
shouldn't it be enough?
Oren
Farabi_Altera
4 years agoHi Oren,
If your design can't set rx_digital_reset longer than 250ns, due to hardware limitation, you can reduce the bit width of the FPGA fabric interface width from 32bits to 16bits to shorten the data deserialization time.
regards,
Farabi
- Farabi_Altera4 years ago
Hi Oren,
I am transferring this case to community support. If you have new question, feel free to open a new thread to get support from Intel. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
