9 years agoMultistage pipelined multiplexer
Hello, My design has to switch between four - 128 bit wide buses. Using a simple coded mux (even with registered inputs and outputs) causes Fmax to drop to unacceptable levels. I'm thin...
9 years ago --- Quote Start --- Do you know if Altera has a similar component ? --- Quote End --- Probably not. Personally I like to have HDL code for useful components, rather than use a vendor black-box. The pipelined mux will map directly into 4-LUT or 6-LUT FPGA architectures - just set the parameters correctly. Cheers, Dave
