9 years agoMultistage pipelined multiplexer
Hello, My design has to switch between four - 128 bit wide buses. Using a simple coded mux (even with registered inputs and outputs) causes Fmax to drop to unacceptable levels. I'm thin...
9 years ago --- Quote Start --- I'm thinking to use a multistage pipelined MUX --- Quote End --- Good thinking ... I've already written one for you ... Download the code from Post#5 http://www.alteraforum.com/forum/showthread.php?t=41601 View the PDF to understand the construction of the mux. Cheers, Dave
