14 years agomultiprocessor: Share same variable
Hi , I try to implement a c-code for multiprocessor architecture(3 CPU). I need to know if it is possible that the three processor share the same variable. For example i declare an integer "var...
14 years agoI think the mailbox is not supported anymore.. you should use onchip + hardware mutex
