14 years agomultiplier delay of embedded multiplier
Hi, I am designing an custom hardware and it requires multipliers, so since there are embedded multipliers available in cyclone II, I decided to use them by using the the multiply symbol in my ...
14 years agoWe need to separate the idea of registers in RTL and those inside mult block.
If you infer with * symbol then you can only add register on input or output but not inside. if you use megawizard you can additionally add registers inside as well as on inputs/outputs. As far as I know you cannot infer internal pipe and I think it defaults to none.
