15 years agoMultiplexer Output Glitching
Hi all, I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue: module mult...
15 years agoAvoiding glitches in combinatorial circuits brings you into the field of "Asynchronous Sequential Switching Circuits" and "Asynchronous State Machines". Rewriting the equation will not really help as everything depends on the relative path delays as produced by the fitter and these will vary while compiling the design after each design change/addition.
