14 years agoMultiple PLL's in cyclone III
Greetings
I filled up one PLL in a cyclone III design and need to add another clock that is skewed -2.5 ns in another PLL. How close is PLL 1 to PLL2 and PLL3? Are they all accurate to one another or are they not to be trusted. Thanks3 Replies
I would NOT trust different PLLs. Same PLL - OK, two different PLLs even if the source the same - not trustable.
What does "Clock compensation" mean. I see it here in the PLL megawizard? can you digress? thank you
You can set the clock compensation mode on one of the PLL's output clocks.
One of those modes should let you meet your needs.
