13 years agoMultiple pin error?
Seems like a dumb question, but its strange to me as I havent used this version of Quartice for a bit. I have a Web Edition. In trying to compile the EP3C55 I get 3 multiple pin error messag...
12 years agoHi ,
I have removed all the additional pin assignments which were imported from DE2_pin_assignemnet file.But still getting ERROR.Please find the attached pin assignment doc and error file. Below is top level pins that I am using. module rs232lab( input CLOCK_50, // 50 MHz clock input [3:0] KEY, // Pushbutton[3:0] input [17:0] SW, // Toggle Switch[17:0] output [6:0] HEX0,HEX1,HEX2,HEX3,HEX4,HEX5,HEX6,HEX7, // Seven Segment Digits output [8:0] LEDG, // LED Green output [17:0] LEDR, // LED Red inout [35:0] GPIO // GPIO Connections // UART output UART_TXD, // UART Transmitter input UART_RXD, // UART Receiver // LCD Module 16X2 output LCD_ON, // LCD Power ON/OFF output LCD_BLON, // LCD Back Light ON/OFF output LCD_RW, // LCD Read/Write Select, 0 = Write, 1 = Read output LCD_EN, // LCD Enable output LCD_RS, // LCD Command/Data Select, 0 = Command, 1 = Data inout [7:0] LCD_DATA // LCD Data bus 8 bits ) // All inout port turn to tri-state assign GPIO = 36'hzzzzzzzzz; Thanks, Gagan
