16 years agoMultiple LVDS inputs from Multiple sources- without DPA support
Hi i have a design working with Stratix II FPGA , it uses 44 LVDS inputs using DPA receiver for each , (eleven source , different distances, each sending 4 LVDS lines) now trying to find a ...
16 years agoHi
I'm using the same clock for all ( transmitters and receivers) currently using stratix II 30 672 pin , now trying to move to stratix IV GX or Arria II Gx, with 700-1100 pins , chip as possible, If I'll use the column LVDs then I will need a PLL for each of the sources (4 lines group) ,since each 4 lines are coming from different source , this will consume PLLs, and also doesn't give me any real time phase alignment .. to what clock freq can I use the column LVDSs ? thanks
