16 years agoMultiple LVDS inputs from Multiple sources- without DPA support
Hi i have a design working with Stratix II FPGA , it uses 44 LVDS inputs using DPA receiver for each , (eleven source , different distances, each sending 4 LVDS lines) now trying to find a ...
16 years agoHi
all the LVDS use the same clock frequency,but each four pack travels different distance, even from different boards, its about 150-200Mhz DDR (up to 400Mbps). (I'm not sending Clock attached to the data , I'm using the DPA to receive all of them) even If I will send clock (sending the data at higher freq and using one of the lines as clock) - then I will need 11 clock inputs and 11 PLL's..
