16 years agoMultiple LVDS inputs from Multiple sources- without DPA support
Hi i have a design working with Stratix II FPGA , it uses 44 LVDS inputs using DPA receiver for each , (eleven source , different distances, each sending 4 LVDS lines) now trying to find a ...
16 years agoWhat's the data rate? Are the 11 sources all clocked off the same source clock? If they were completely independent and you absolutely needed DPA, then you would need 11 left/right PLLs, which I don't think any device has. I assume a single PLL/DPA can capture multiple inputs?
Can your sources send a clock signal, or is it just data with each?
