16 years agoMultiple JTAG control
Hi, Is it possible to use a single NIOS II IDE to control two independant JTAG/USB-blaster based systems? (for example use USB port 1 to control one system and use USB port 2 to control another sy...
16 years agoDoesn't work here.
Plug in two byte blasters and the system only sees one. It also goes through the 'installing new hardware' procedure. Seems to me that byte blaster all have the same USB serial number, so Windows can't work out which one is which.
