12 years agoMultiple High Speed ADCs via serial LVDS
Hi everybody, for a new system there is the need to digitize data with 12 Bit/80Msps from up to 20 channels. To date the idea would be using multiple Quad ADCs with serial LVDS links source ...
12 years ago --- Quote Start --- For multi-channels or multi-ADC chips, is it possible that the DCO do not need inside FPGA? Can we use internal same frequency clock as ADC data reference clock? So we can save one lvds channel. --- Quote End --- The shift between the supplied ADC clock and the resulting output DCO clock is not well specified making it (IMHO) impossible to set the exact capture point. So you need to use the DCO clock itself to sample the data streams.
