17 years agomultiple clock domain instruction
Hi, guys, I am now studying the document named "building systems with multiple clock domains" which is in Quartux II Handbook, Volume 4. in page 11-8, it says that I need to find something...
17 years ago --- Quote Start --- standard is the design name for which ever device you are targeting, and the bdf should be in that directory. did you check: <Nios II EDS install path>\examples\<verilog or vhdl>\<board version>\standard --- Quote End --- thanks for the reply. Exactly, there is such a directory! I thought the bdf file might be there after I generated the updated system using SOPC builder; however, it is not there!! :confused: where else can i check? thank you
