multi-phase clock usage from the same one PLL
I would first think about using the provided SERDES DPA IP though, e.g. by twofold oversampling your input and adapting the design respectively.
If you want however to design multi-phase sampling on your own, you should study SERDES DPA respectively soft CDR topology. They essentially have the same problem you are facing and solved it.
Hi, FvM
Thanks for your reply. Now this IP could only support the speed which is more than 150Mbps. The speed of our tx is 100Mbps, that means I need use 3 times sample rate compared to this speed. I don't know if there's enough toggle to make the soft-cdr work well. (But I will try this solution in out project. ) Based on this consideration, I try to design one soft-cdr which I need learn more knowledge about this technology.
BRs,
Lambert
- FvM3 years ago
if I understand right, the solution in SERDES IP is to drive the deserializer with actually selected vco_ph clock and perform domain crossing with parallel data. That's what I do in different kinds of soft CDR designs for FPGA series that don't provide hardware DPA (Cylone III to Cyclone 10, MAX 10).- lambert_yu3 years ago
Contributor
Hi FvM,
Thank you very much for providing this information.
We will design one soft-cdr design based on the intel fpga. I expect there's opportunity to receive your guidance in the future. Any small help will be greatly appreciated.
BRs,
Lambert
