14 years ago
MTI VO filetype
Can somebody explain me what is MTI and the significance of MTI VO filetypes.
    Thanks a lot Schmalisch for the timely advice. . I included all the libraries in my work folder including those of alt_mf. Now I don't have anymore errors during the compilation. I shall now test the design.
    For simulating the CRC core just use the crc.vo file. This file includes the functionality of crc.v and crc_altcrc.v.
    For synthesis you need the crc.v and crc_altcrc.v file.
    Thanks a lot. Is there anyway to view the encrypted file.
    I am trying to customize the data generator within the traffic controller module in the following design
    http://www.alterawiki.com/wiki/10g_ethernet_and_10g_base_r_phy_interoperability_hardware_demonstration_design
    The design provides a script to run the design. But I am writing my own testbench to do the functional simulation in modelsim. But the problem occurs when I try to simulate the data generator module separately (due to the encrypted files). The error says that the modules ( which are in encrypted files) as not found or missing. Is there anyway to overcome this problem.
    Ok, in this particular case the vo file includes a obfuscated simulation model of the CRC core.
    For synthesis Quartus will use crc_altcrc.v which is a somehow encrypted implementation.
    I am using the crc megacore function. It generates a crc.v and crc.vo . I am just interested to know in general, why do we use vo filetypes, is there any specific advantages while using them in our design.
    I think this is very clear. The vo file contains Verilog code.
    How should I know what exactly it implements? I don't know with which tool or IP core it was generated.
    Thanks Schmalisch.. But can you explain me in simple terms the contents of the vo filetype. I think it is only netlists but is there anything else..
