8 years agomSGDMA Transmission Data Missing
I am trying to transfer data using the mSGDMA QSYS cores in Quartus 17 from on-chip memory on an Arria V FPGA to a buffer allocated in Windows through PCIe and Jungo’s Windriver. Typically, the core ...
8 years agoIf you see blocks of zeroes, maybe you could make sure that your software only uses non-zero data and then trigger on a null data word?
Something else that could be worth checking is that the buffer that you use for the DMA transfer is not sharing its cache line with another variable. This means obviously that it can't be on the stack (i.e. a local variable). If it is a global or static variable, you can use the compiler's __attribute__ ((aligned(32))) to align it's address, but you must also make sure that its size is a multiple of 32. If it is an allocated buffer, some C libraries provide an aligned malloc, or else allocate a bigger buffer and use some bit manipulations to use an aligned zone within the buffer.
