13 years agomSGDMA stride reads/writes
Has anyone used the Stride feature (available with the extended descriptor)? I using the Qsys PCIe example design on the wiki. When I enable the extended descriptor and stride option, the data tran...
13 years agoWhat you describbed can be accomplisted with a MM-->ST mSGDMA (i.e. no write master) and if your FIFO is wider than the data path then a data format adapter will convert it over to the correct width. For example if the PCIe slave width is 64-bit with a burst length of 32 I would use the mSGDMA in MM-->ST mode with a 64-bit data path, max burst length of 32 and then use a 1:4 data format adapter to take four 64-bit beats and cram them into the 256-bit FIFO.
Of course you can do this with a memory mapped FIFO but it would take some additional logic to funnel multiple addresses into the same word before pushing it into the FIFO. Most of the time users will create a FIFO with a really large address span and alias the addresses internally to push data in. I personally never use MM for FIFOs unless absolutely necessary and in your case I don't think that's the case at all. Avalon-ST exists for stuff like this so I would simplify things and use the most appropriate interfaces to get your job done instead of using MM for things it's not really meant for.
