8 years agoMSEL driving
Hi, On page 246 Arria10 Handbook says: "To select a configuration scheme, hardwire the MSEL pins to VCCPGM or GND without pull-up or pull-down resistors." On page 247 Arria10 Handbook says: "...
8 years agoThe last part is a bit speculative. I assume that the FPGA would read the MSEL pins when the nCONFIG signal goes high, but if you need to rely on that, maybe you should check this first with a dev kit, by for example powering on the kit, then change the MSEL DIP switches, trigger a reconfiguration and check that the FPGA does indeed use the new MSEL value and not the old one.
