Move data from NIOS to hardware and then back to NIOS
I am trying to do a little calculation in hardware but I'm stuck on how to get started. I'm a complete newbie, but after reading a lot of manuals and demos, I figured out that I could have a soft processor NIOS that could accept C code. So using a basic computer configuration of the the DE2 (it comes with the University Program), I then created a NIOS BSP project. After trying many times, I managed to get everything compiled and the code below to run on the target hardware.
void main(void) { int line1[] = {1, 2, 3, 4, 5, 6, 7}; int line2[] = {1, 2, 3, 4, 5, 6, 7}; //--- Do this in verilog! int i; int store_val = 0; for(i=0; i<7; i++) { store_val = store_val + (line1*line2); } //--- verilog_end } Now the next step is that I want to do the calculation in the for-loop section in hardware using verilog rather than C. I have three main queries: 1) How to write that for-loop function in verilog? 2) Where do I save the verilog module? 3) When I have the verilog equivalent, how do I move the values contained in the two C arrays to the verilog module to do the calculation and then send back 'store_val' to the BSP project? I read about DMA in other posts but I don't know how to do that process. This is confusing me. Any help is greatly appreciated. Thank you very much14 Replies
Good catch, I never noticed that bug since I have always used the code in an infinite loop mode. I'll update the design some time this week to correct that.
I would probably make your own code to test your own hardware since most of the mSGDMA code is setup to setup random test buffers and all kinds of non-practical stuff. Your code should end up being a faction of the length if you code it for your own application. You could run an uncached malloc (see Nios II software handbook for more details) to allocate a pointer to some location in the heap and then dereference that point to populate the buffer. Sorry I linked the wrong page, I meant this one: http://www.alterawiki.com/wiki/modular_sgdma_video_frame_buffer If the read and write lengths are not the same then you'll need to use a pair of DMAs since a DMA typically performs the same number of reads as writes. It would be possible to hack the dispatcher HDL to support different read and write lengths but I wouldn't recommend attempting that just yet. - Altera_Forum
--- Quote Start --- If you are running the included software from the mSGDMA design make sure you change the settings near the top of the main.c file to represent your own system memory address base and span. --- Quote End --- OK, I found my mistake. I had the CPU Reset and Exception vectors on the SDRAM. I have now changed the DATA_SOURCE_BASE address to start further into the memory, and I can see the source and destination memory being the same after I run the program in debug mode. Just a quick question: Is the statement ' test_counter = 0;' not supposed to be before the start of the 'do' loop? Because '(test_counter < NUMBER_OF_TESTS)' in the 'while condition' will always be true otherwise. The next step for me is to try to populate the source buffer with the 36 data values contained in my_2d_array, but I am struggling to do this. I've set MAXIMUM_BUFFER_SIZE 36 and NUMBER_OF_BUFFERS 2 but I am not too confident with the pointer notation to get first 36 addresses after DATA_SOURCE_BASE to contain those values. Can anybody please help me with this? --- Quote Start --- If you want to see a simplier application check out this design example which is configured for MM --> ST which performs frame buffering to an LCD. The only difference is you would use MM --> MM and setup the descriptors slightly differently. http://www.alterawiki.com/wiki/modular_sgdma --- Quote End --- Where is this design example? I can't find it on that website. --- Quote Start --- With the mSGDMA if you wedged your block between the read and write masters then your control would be just triggering a normal DMA transfer (assuming for every input there is one output from your block). --- Quote End --- Now that you mention to assume every input = output, I am realizing it is not the case with that UP IP block. This block takes in one 8-bit value at a time and uses altshift_taps shift register to get the data in the right format to do its processing. Anyway, this is not a problem for now as I just want to get those 36 values in my array moved around using Avalon ST and I will have to write my own core later. - Altera_Forum
That's correct, to do this with the SGDMA on the ACDS you would need to control a pair of SGDMAs for doing MM-->ST and ST-->MM. With the mSGDMA if you wedged your block between the read and write masters then your control would be just triggering a normal DMA transfer (assuming for every input there is one output from your block).
The pipeline bridge isn't necessary, it's just included to add some additional pipelining to the design. If you are running the included software from the mSGDMA design make sure you change the settings near the top of the main.c file to represent your own system memory address base and span. I did a minor update to that software to fix a bug which would cause the source and destination buffers to overlap so make sure you have the latest main.c file. You probably don't need to modify many of the settings. The length width parameter just dictates the maximum number of bytes you can transfer in a single transfer. For example if you chose 20 bits that means you can transfer slightly less than 1MB of data in a single descriptor. The only reason why it's a parameter and not hardcoded to be 32-bits is that when a timing critical path shows up in one of the masters it can typically be solved by just reducing that length register width to something more sensible (being able to transfer ~4GB in one shot doesn't make sense in SOPC Builder which only has a 4GB space per master anyway). Since you are dealing with MM to ST the symbol size is 8-bits. So if your component has an 8-bit input/output you can still setup the mSGDMA for a wider data path. This will help increase your memory throughput since multiple symbols can be fetched every clock cycle. I would use the C code as a guideline, most of it has nothing to do with the mSGDMA so it may end up leading to confusion. If you want to see a simplier application check out this design example which is configured for MM --> ST which performs frame buffering to an LCD. The only difference is you would use MM --> MM and setup the descriptors slightly differently. http://www.alterawiki.com/wiki/modular_sgdma - Altera_Forum
--- Quote Start --- You might have an easier time using this instead: http://www.alterawiki.com/wiki/modular_sgdma --- Quote End --- Yeah the UP core has a ST port into the core and another ST port coming out of it. Before I slot the ST component in between the read and write masters and assuming that my original data is generated by the CPU and stored in the SDRAM, and the result after going through the UP core will also go in the SDRAM, do I need: - modular dispatcher (MM to MM), Read master and Write master like in the example file or - modular dispatcher (MM to ST) & Read master, and modular dispatcher (ST to MM) & Write master My feeling is that it is the first option but I just want a confirmation because it is my first time using a DMA type component. If suppose instead I had used the standard SG-DMA component available in SOPC, would I then need two SG-DMA components, i.e. MM to ST at transmission and ST to MM at receiver? OK, in the meantime I tried to adapt the example given in the website to my DE2-115 board but the msgdma keeps spinning and my NIOS program gets stuck at loop 'while (sgdma_interrupt_fired == 0) {}'. How do I find the cause of the error? Could this error due to the fact that I have not fully copied the SOPC example design file because I have not used the Avalon-MM Pipeline Bridge and the 'DDR SDRAM Contorller with ALTMEMPHY'? I just have a CPU, SDRAM controller and the Modular SGDMA components (all running at same clock rate) at the moment. I did not add those components because I don't understand their purpose but if needed, I will do it. Now assuming I get that example file working after adding all these extra components and clocks, what changes will I need to bring to the parameter setttings of my Read Master and Write Master components if the data to be transferred is now a 3 x 12 array of u8 integers, i.e. 36 bytes, defined as below in my C code. alt_u8 my_2d_array[3][12] ; //Fill in the values source_buffer = &(my_2d_array[0][0]); The Data Width setting goes to 8. How about Length Width and FIFO Depth, and the other settings? What are the major changes in the example 'main.c' file to I need to do? Thanks - Altera_Forum
Assuming the UP IP core has an ST port into the core and another ST port coming out of the core then you could just slide it in between the read and write masters and do the transfer all in one shot. Just look at the Nios II software code to find out how to setup a descriptor. - Altera_Forum
--- Quote Start --- No, if you use a DMA you don't need PIOs or dual part memories. One way to do it would be to use an Avalon Stream interface between the DMA and your hardware. You may need a FIFO between the two in some cases but this can be added in SOPC builder. The PIOs are fine for slow systems with little amount of data but they are less efficient than a DMA. Using a dual port memory and an Avalon slave interface should be easier to make, but it seems that you will handle a lot of data so it may be impossible to use on-chip memory to store your data. That's why I'd recommend a DMA. If you are new to Verilog you may want to start with something simpler than this project though. --- Quote End --- Thank you for the advice. I will use nophutwern's advice to use modelsim to simulate my verilog module. It is true that I don't know about Verilog and this is why I wanted to do a simple calculation of sum and product as as a starting phase. I can't change my project now..too late :( Anyway, to go back to your suggestion of using Avalon Streaming interface, I found a similar example to the StratixII_DSP_Kit-v1.0.0 design example but this time it has ST interface. This one a is a ready-made SOPC component in Verilog available in the Altera UP Video cores called 'altera_up_avalon_video_edge_detection'. It is available from the altera_upds_setup.exe file in on the ftp download area of Altera Univeristy Program. I don't care what calculations that component is making but at least we know it is a module written by experts. This module takes in 8-bit data of an image and has Avalon Stream Sink and Source. From what I found on this foum, I have to use SGDMA to interface with this module, something like CPU-> SGDMA(Mem to Stream) -> Altera UP module -> SGDMA (Stream to Mem). My question is how to initiate the SGDMA transfer to stream data through the UP module? I read about alt_avalon_sgdma_open, _start, _stop etc but I am not sure how to call these functions in my NIOSII C code. Can somebody please give me an example C code that will do that process assuming that I have a 2-d array of integers already initialized at the top of my C code? I also have the CPU connected to the SDRAm and SRAM available on my board. Thanks a lot. - Altera_Forum
The PIOs are fine for slow systems with little amount of data but they are less efficient than a DMA. Using a dual port memory and an Avalon slave interface should be easier to make, but it seems that you will handle a lot of data so it may be impossible to use on-chip memory to store your data. That's why I'd recommend a DMA. If you are new to Verilog you may want to start with something simpler than this project though. - Altera_Forum
--- Quote Start --- It depends on the kind of performance that you want. You can create an Avalon slave interface and have the CPU write all the integers one by one to your hardware. But if the only thing your hardware does is a multiplication I don't think it ill be a lot faster than doing it in software. If you want a bettor performance it makes sense to use a DMA that will read the integers from your memory and give them to your custom hardware. I'm not a Verilog expert, but I think that if you do a search on the forum you should find some Verilog templates for Avalon slave interfaces. --- Quote End --- This simple 'sum of products' example is a starting step for me. Later on, there will be larger arrays and more calculations, something similar to an image processing task. So if I create a dma and access the data using the dma address in nios, how do i interface that data with the simple 'sum of products' verilog module? Do i still need those PIO, fifo, etc? Sorry for asking such basic questions. - Altera_Forum
If you want a bettor performance it makes sense to use a DMA that will read the integers from your memory and give them to your custom hardware. I'm not a Verilog expert, but I think that if you do a search on the forum you should find some Verilog templates for Avalon slave interfaces. - Altera_Forum
--- Quote Start --- DMA is not the right way to communicate between nios and hardware. --- Quote End --- The reason I talked about DMA is because I saw from a Reference Design (StratixII_DSP_Kit-v1.0.0) that the author reads an image from the flash memory card into a DMA buffer, apply an edge detector operation to the data, then sends it back to the DMA to be displayed on the VGA. Suppose my data is not just 2 arrays of 7 integers but instead 2000 arrays of 1000 integers or a 2-D array of [2000][1000] if it is an image, do I still use FIFOs or DUALPORT-RAMs to communicate with hardware? My idea was to make an SOPC component with Avalon MM slave interfaces out of the verilog code (another thing I don't know how to do!) and 'slot it' in the data flow from the CPU data master in between two DMA buffers as in that reference design mentioned above. But I guess I have to do it the PIO, FIFO,or DUALPORT way for now.
