15 years agoMove data from NIOS to hardware and then back to NIOS
I am trying to do a little calculation in hardware but I'm stuck on how to get started. I'm a complete newbie, but after reading a lot of manuals and demos, I figured out that I could have a soft pro...
15 years ago --- Quote Start --- If you are running the included software from the mSGDMA design make sure you change the settings near the top of the main.c file to represent your own system memory address base and span. --- Quote End --- OK, I found my mistake. I had the CPU Reset and Exception vectors on the SDRAM. I have now changed the DATA_SOURCE_BASE address to start further into the memory, and I can see the source and destination memory being the same after I run the program in debug mode. Just a quick question: Is the statement ' test_counter = 0;' not supposed to be before the start of the 'do' loop? Because '(test_counter < NUMBER_OF_TESTS)' in the 'while condition' will always be true otherwise. The next step for me is to try to populate the source buffer with the 36 data values contained in my_2d_array, but I am struggling to do this. I've set MAXIMUM_BUFFER_SIZE 36 and NUMBER_OF_BUFFERS 2 but I am not too confident with the pointer notation to get first 36 addresses after DATA_SOURCE_BASE to contain those values. Can anybody please help me with this? --- Quote Start --- If you want to see a simplier application check out this design example which is configured for MM --> ST which performs frame buffering to an LCD. The only difference is you would use MM --> MM and setup the descriptors slightly differently. http://www.alterawiki.com/wiki/modular_sgdma --- Quote End --- Where is this design example? I can't find it on that website. --- Quote Start --- With the mSGDMA if you wedged your block between the read and write masters then your control would be just triggering a normal DMA transfer (assuming for every input there is one output from your block). --- Quote End --- Now that you mention to assume every input = output, I am realizing it is not the case with that UP IP block. This block takes in one 8-bit value at a time and uses altshift_taps shift register to get the data in the right format to do its processing. Anyway, this is not a problem for now as I just want to get those 36 values in my array moved around using Avalon ST and I will have to write my own core later.
