15 years agoMove data from NIOS to hardware and then back to NIOS
I am trying to do a little calculation in hardware but I'm stuck on how to get started. I'm a complete newbie, but after reading a lot of manuals and demos, I figured out that I could have a soft pro...
15 years ago --- Quote Start --- DMA is not the right way to communicate between nios and hardware. --- Quote End --- The reason I talked about DMA is because I saw from a Reference Design (StratixII_DSP_Kit-v1.0.0) that the author reads an image from the flash memory card into a DMA buffer, apply an edge detector operation to the data, then sends it back to the DMA to be displayed on the VGA. Suppose my data is not just 2 arrays of 7 integers but instead 2000 arrays of 1000 integers or a 2-D array of [2000][1000] if it is an image, do I still use FIFOs or DUALPORT-RAMs to communicate with hardware? My idea was to make an SOPC component with Avalon MM slave interfaces out of the verilog code (another thing I don't know how to do!) and 'slot it' in the data flow from the CPU data master in between two DMA buffers as in that reference design mentioned above. But I guess I have to do it the PIO, FIFO,or DUALPORT way for now.
