14 years agoMotor Control with DSP builder Adv BlockSet
Hi Guy I am in the process of examining the feasibility of the putting the Field Oriented Control algorithm for Motor Control on the Cyclone III FPGA. My sampling rate is just 10K/s and woul...
14 years agoHi Kelvin
Thanks for your response. This kind of information it exactly what I want from this survey. So did you implement floating point in your motor control design. Can your tell me about the total number of logic elements you used in the design, and the folding ratio (I believe you use the TDM). I believe the DSP builder is a great way to go (if it work as advertised without too much caveat) just for the sake of the combination of the Design and implementation phase. It probably will be easier for documentation and maintenance too. For writing the whole algorithm by hand in VHDL, it seems it will be tedious to arrange the state machine for reusing the same floating point arithmetic unit to save resource. Hi James, what do you think of my thinking here? Please feel free to comment. And Kelvin, Does the Falcon kit already come with the example design from using the DSP builder? Many thanks in advance.
