14 years agomore components in paths
hiii alll i am facing too many components in my critical path.. I know it depends on coding..but is there anything i can do in synthesis to reduce this total delay
14 years agoOh thanks guys...And yes RYSC the inputs and outputs should be registered...
In this case as you can see the input is fed directly to a priority kinda logic around 4-5 mux...and the result is fed to a reg and den the output.. the constraint like fast input reg also fails because the input has not been registered.. Do you think the logic needs a change or it can be done with some synthesis constraints???
