14 years agoMoore and Mealy
I have been analysing the difference between implementing an identical system using a Moore and a Mealy state machine. The Moore has the advantage of being simpler to implement and more im...
14 years agoA mealy machine in the 'pure' form is usually combinational logic combining the state register with the inputs to the FSM. So I guess because the inputs are combined combined the state register output it is more suceptible to glitches. I don't really consider the FSM type factors in glitch/glitch free outputs since the output of a moore machine can have glitches too due to various delays through combinational logic that might be between the state registers and the output. I would say mealy FSMs on average have more glitch time than moore FSMs but even that's a generalization that isn't always true.
When I design FSMs I don't even worry about what type it is. Typically I just care about simplicity and keeping combinational delays to a minimum. Whether it's a moore or mealy, if it gets the job done and hits the Fmax I want then I don't really care what type it is :)
