14 years agoMoore and Mealy
I have been analysing the difference between implementing an identical system using a Moore and a Mealy state machine. The Moore has the advantage of being simpler to implement and more im...
14 years agoThank you very much folks.
I am still a bit confused about the word glitch. When you read that Mealy machines can cause glitches at the output. Does that imply if the input glitches for whatever reason that glitch will be observed at the output.
