16 years agomodule cpu not found
hello I am having a problem using C program in NiosII IDE. I am using the hello world template project from nios II. I have used the SRAM controller provided by the University Program. when i'm ...
16 years agoHi fabmal004, did you ever find the cause of this issue?
It turns out that I have just picked up a project made in 7.2sp3 and I have got the same error message. So far I have tried re-installing Quartus, Nios II and the IP megacore incrementally from v7.2 sp1 through to sp3. I have also had a look through the installed sopc folders and I can see that the nios cpu component files definately exist in my install, but for some reason Nios is not finding them. Anyone else have any ideas or a solution??
